cbfr337
Dec 07, 2021Aspirant
RAX35V2 Dropping internet every hour for about 3-5 secs
RAX35V2 Dropping internet every hour for about 3-5 secs. How to fix
Dec 10, 2021Guru - Experienced User
Any progress on this?
cbfr337
Dec 10, 2021Aspirant
Sorry for the delayed response. Found out that the ISP had it set to 1 hour. Had to go around an around with them. They said it was my router but pulled a lease on a computer directly off their modem which was 1 hour.
- FURRYe38Dec 10, 2021Guru - Experienced User
Great fine and good work. Way to take it to the 'man'.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - plemansDec 10, 2021Guru - Experienced User
Still don't know what actual modem/gateway this is.
- michaelkenwardDec 11, 2021Guru - Experienced User
Yes. The ISP's answer seems like one of those "pass the buck" responses.
It doesn't get to the bottom of the problem. Not really a "solution"
