LanceBurbank
Dec 22, 2021Aspirant
RAX35v2 is not allowing Dropbox to sync
I have an RAX35v2 router. Originally Dropbox worked fine with it, but now the router appears to be blocking Dropbox syncing. Sync works fine when I use another router so I'm ruling out the Mac OS or ...
- Dec 26, 2021
Seen odd things with Monterey. I'd contact Apple and let them know what your seeing betwee your two Macs. I've filed s few items against OSX 12 since beta started. They fixed most of them. One of them was Monterey would crash if I connected to my NAS via SMB. Another was scrolling with mouse in text exit would cause the app to hang.
Dec 23, 2021Guru - Experienced User
Is Smart Connect, Beamforming and MIMO and WMM Enabled on the router?
- LanceBurbankDec 23, 2021Aspirant
Thanks for the reply. I really appreciate it.
Firmware = V1.0.4.100_2.0.64
Smart Connect = NOT enabled
Beamforming = Enabled (5g)
MIMO = NOT enabled
WMM = Enabled
- FURRYe38Dec 23, 2021Guru - Experienced User
Same thing happens if Smart Connect is enabled?
- LanceBurbankDec 25, 2021Aspirant
I'll have to try Smart Connect.
Here's my modem info:
Taking a look on the Spectrum website because the modem is not identified except for a Spectrum label on the external case, looks like a Spectrum D3.1 eMTA DOCSIS 3.1 Advanced Voice Modem.
Sorry, forgot to respond re the modem. Unfortunately, I don't see any name/model info on it. It's just labeled Spectrum.
Taking a look on the Spectrum website, looks like a Spectrum D3.1 eMTA DOCSIS 3.1 Advanced Voice Modem.
Thanks again.
