LanceBurbank
Dec 22, 2021Aspirant
RAX35v2 is not allowing Dropbox to sync
I have an RAX35v2 router. Originally Dropbox worked fine with it, but now the router appears to be blocking Dropbox syncing. Sync works fine when I use another router so I'm ruling out the Mac OS or ...
- Dec 26, 2021
Seen odd things with Monterey. I'd contact Apple and let them know what your seeing betwee your two Macs. I've filed s few items against OSX 12 since beta started. They fixed most of them. One of them was Monterey would crash if I connected to my NAS via SMB. Another was scrolling with mouse in text exit would cause the app to hang.
nielsvds
Dec 26, 2021Luminary
Spectrum is using Hitron for there cable modem/router : https://us.hitrontech.com/products/service-providers/e31n2v1-cable-modem-router/
LanceBurbank
Dec 26, 2021Aspirant
OK, I logged into my Spectrum account and discovered that I have a Motorola E31U2V1.
Also ... my very old Macbook Pro running OS Catalina actually syncs fine with Dropbox (using same network and router). So, maybe not the router after all. Having said that, my Macbook Pro running Monterey, the computer I'm having issues with, works fine when using my mother-in-law's router. So just really puzzled by all of this.
- FURRYe38Dec 26, 2021Guru - Experienced User
- LanceBurbankJan 08, 2022Aspirant
Issue seems to be resolved. Beats me as to how. Guessing that some application that had caused a conflict was updated, but who knows. I spent hours and hours trying to troubleshoot this. Nothing worked. And now suddenly it's all good. đ
