blasf69
Nov 17, 2020Aspirant
RAX35V2 Walmart special
Hello, I just purchased a Netgear Nighthawk AX4 AX3000 4 stream router. On the bottom sticker Model: RAX35 When I log into the web interface the model displayed is RAX35V2 I searched google for R...
Nov 19, 2020Guru - Experienced User
I didn't even find that firmware for any of the RAX devices. Or anything on a V2 other than the FCC
Christian_R Any idea whats going on with this version?
Eagle-Two
Nov 20, 2020Apprentice
If you go to the downloads link in the banner and type in RAX35, I see both v1 and v2 routers. When I compare product data sheets, I see v2 has a different processor and Netgear Armor. The firmware versions also looks to be different. I have a RAX35v1 with disconnect issues when AX is enabled so hopefully you have more success with v2. In the router administration under Advanced, Administration, and Router Update, you should be able to check to see if there is a newer firmware version.
- plemansNov 20, 2020Guru - Experienced User
it is showing up now.
