faja1130
Apr 20, 2024Aspirant
RAX36S Guest Network port restrictions
I have come across situations where when connected to the guest network, there are certain limitations. For instance, my wireless printer was not visible to my iphone airprint as a device. I changed the wireless printer to connect to the main network and all is good.
Is there a document which lists the various restrictions of the guest network (such as blocked ports, etc) as opposed to the main network? Or are these restrictions defined somewhere within the router config?
Thank You
- They are not configurable. It's internal firmware low-leven stuff.
- microchip8MasterGuest network only works on WiFi, not LAN. It's separated from the main one by using virtual devices and firewall tools.
- faja1130Aspirant
are these virtual services and firewall tools configurable? if so, where are they within the router admin interface...?
Or is it within the firmware...
- microchip8MasterThey are not configurable. It's internal firmware low-leven stuff.
