withallthat82
Sep 24, 2020Follower
rax38 ax3000
I got the rax38 from sams club and every since setting it up been having issues
sometimes the wifi networks won’t appear and i have to reset the power to it
and whenever i plug in a ethernet in it shuts off the wifi and I login to the admin it shows wifi active and I have to reset it
It has the newest firmware
Never had issue with my old netgear and I can’t return this
1 Reply
- Christian_RNETGEAR Employee Retired
Hi withallthat82,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
