SomeGuy_S
Sep 01, 2023Aspirant
RAX38v2 cables not connected
I have a Nighthawk AX4 RAX38v2. It worked fine, but I had to turn it off for two weeks and when I turned it back on, it stopped working. The internet access LED does not light up. After rebooting, th...
- Sep 02, 2023
Something at your location with your ISPs ONT isn't working with the RAX router. Something to check with the ISP about.
Sep 01, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- SomeGuy_SSep 01, 2023Aspirant
I just tried resetting and rebooting in the sequence you wrote - didn't help. I also changed the DHCP, but that didn't help either.
I don't know the Mfr and model# of the modem/ONT of the ISP that the NG router is connected to. But I can call my ISP tomorrow when they start working again if that could be the cause.
There is a CAT5 LAN cable connected to the NG.
