SomeGuy_S's avatar
SomeGuy_S
RAX38v2 cables not connected
I have a Nighthawk AX4 RAX38v2. It worked fine, but I had to turn it off for two weeks and when I turned it back on, it stopped working. The internet access LED does not light up. After rebooting, th...
  • FURRYe38's avatar
    Something at your location with your ISPs ONT isn't working with the RAX router. Something to check with the ISP about.
