Broulee
Mar 27, 2021Aspirant
RAX4 Router regularly drops WiFi connection to internet. Power off/on reboot resolves annoying prob
An annoying issue. Is there a setting I should try. I have done a factory reset and new setup, but problem still occurs regularly.
Mar 27, 2021Guru - Experienced User
What firmware are you on?
What modem is it connected to?
how frequently is it happening?
Do devices say "connected no internet" or what exactly happens?
- BrouleeMar 27, 2021Aspirant
- michaelkenwardMar 28, 2021Guru - Experienced User
It is almost impossible to understand what is going on at your end, given how little information you have provided. But you seem to be trying to connect a router to a modem router.
What is Double NAT? | Answer | NETGEAR Support
I see no sign that you are using one of Netgear's "Mobile Routers, Hotspots & Modems", the subject of this section of this bit of the community.
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routersand here:
- BrouleeMar 28, 2021Aspirant
Thank you. The Netgear router is connected to the Australian Broadband Network. It connects to the internet ok, but regularly, once or twice a day the WiFi drops the internet. I don't think this is an NBN problem as a power off/on the Netgear WIFI/Router fixes the problem.
