R-M-H
Jun 29, 2020Aspirant
RAX40 — Nighthawk AX4 4-Stream WiFi Router
After the latest firmware update, my router sporadically stops broadcasting networks. I have called tech support several times and have gotten nowhere. No issues on the carrier line and I have fact...
Christian_R
Jul 07, 2020NETGEAR Employee Retired
Hi R-M-H,
May you send me a private message with your case number(s) and contact info and I can see if I can get your case escalated.
Thanks,
Christian
Erwin_Jong
Sep 18, 2020Aspirant
Any news on this topic. I flashed the latest firmware on this AP right after purchasing but no client is seeing the SSID while it is not hidden.
Can i otherwise flash an older firmware again to see if that works better ?
