R-M-H
Jun 29, 2020Aspirant
RAX40 — Nighthawk AX4 4-Stream WiFi Router
After the latest firmware update, my router sporadically stops broadcasting networks. I have called tech support several times and have gotten nowhere. No issues on the carrier line and I have fact...
R-M-H
Oct 18, 2020Aspirant
Has this been resolved? I’m hesitant to upgrade firmware.
itsmehuey
Oct 18, 2020Luminary
no it has not. Beta firmware is still in works and being tested. I'm currently using the beta firmware and it's been good for the most part. Awaiting response back from L2 support rep working on my case regarding further tweaks required to the firmware as I did encounter an initial WIFI drop and issues logging into the router admin/debug console..
- cpapy541Nov 12, 2020Aspirant
Any updates I am also having this issueas of 11-12-20, works good for a couple days then I have to reboot the router. Annoying. only since last firmware update
itsmehuey wrote:
R-M-H wrote:
Has this been resolved? I’m hesitant to upgrade firmware.no it has not. Beta firmware is still in works and being tested. I'm currently using the beta firmware and it's been good for the most part. Awaiting response back from L2 support rep working on my case regarding further tweaks required to the firmware as I did encounter an initial WIFI drop and issues logging into the router admin/debug console..
- itsmehueyNov 15, 2020Luminary
cpapy541 wrote:Any updates I am also having this issueas of 11-12-20, works good for a couple days then I have to reboot the router. Annoying. only since last firmware update
itsmehuey wrote:
I've provided the netgear support rep with my feedback and they said they've routed it back to engineering team.. it's all in their hands now, to release an updated firmware for public release.
