edinho10
Dec 20, 2021Tutor
RAX40 - extremely bad wifi speed
I live in a four story house, where the modem is in the basement connected to a given router from the internet supplier. The house is setup so that all internet wall plugs in different rooms in the h...
- Dec 20, 2021
if you're testing them both in the basement and getting full speed and the only thing that changes is the cable when you move it, then i'd be checking into a new cable.
you can check your wan port connection speed.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
