Ghostdragon87
Jun 06, 2020Tutor
Rax40 1.0.3.80_1.0.1 update
Has anyone with the Rax40 router tested the new 1.0.3.80_1.0.1 firmware? I seen some having issues so i'm worried about updating. I just use the modem and router for wifi and nothing special extra and...
rinku
Jun 15, 2020Initiate
Post upgrade to Firmware Version V1.0.3.80_1.0.1, WiFi became unstable. Performed factory reset which didnt help. Resuming Wifi requires reboot of the device. Its annoying that a newly bought router is acting funky and no response from support either. Anyone facing the same issue and have resolved it?
Ghostdragon87
Jun 25, 2020Tutor
I updated my rax40 to the latest firmware and haven't had any issues. I factory reset before and after firmware update though. Have you tried WPA2 because I know theres some reports of issues with WPA3 on some router models. If that don't work I would try downloading the latest firmware onto a pc connected via ethernet, then factory reset the router (pin hole on back held for 7 seconds) then go to routerlogin.net and upload the latest firmware and after router reboots from update, factory reset and setup as new. Alot of work but may help
