tatsumaki's avatar
tatsumaki
RAX40 admin password not reset after factory reset
I applied the new firmware update and my wifi did not come back on after reboot. When I attempted to log in as an administrator the router would not accept my password. I decided to perform a reset by...
  • tatsumaki's avatar
    tatsumaki
    Nov 13, 2022
    I am happy to report that I was able to correct this issue. I was able to use the nmrpflash utility to install new firmware. The newest 1.0.5 and 1.0.4 versions did not fix the issue so I went all the way to 1.0.1.36 and this allowed me back into the router. I will now attempt to update sequentially as I cannot recall what firmware version I was on before.
