andrew3harris
Oct 26, 2020Follower
RAX40 and Alexa Netgear Skill. Alexa cant comminicate with router
The instructions are straightforward so why is this not working?!!! I am trying to enable the Netgear Alexa skill. My AX4 router is up and running. I have Anywhere Access and Remote Login enabled ...
Christian_R
Nov 02, 2020NETGEAR Employee Retired
Hello andrew3harris,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
