ronald_fr
Mar 27, 2020Luminary
RAX40 and iPhone 11
Hello, I encountered some issues with 5G WiFi with various devices, hangs, reset to factory default. No issue since a couple of days and : Yesterday my iPhone 11 (IOS 13.1) had troubles with...
ronald_fr
more about the issue : I also remove the AIRTIME FAIRNESS option to obtain better throughput on my laptop .
BR
Ronald
Christian_R
Mar 30, 2020NETGEAR Employee Retired
Hello Ronald,
May you try changing the WiFi channel on the 5GHz band to see if there are any improvements.
Thanks,
Christian
- ronald_frMar 31, 2020Luminary
Thanks for reply,
but when I called Netgear support ( and paid for it :-( )
- They ask me to change channel and to put 128 ... it worked 2 days and it was worse !
- An other call to support : support rep. connected to my router and said "you are in AP mode, you must not change channel" and back to chan 44
- An other call to support : an other support rep. connected to my router and did not do anything more than the previous one and I said this is enough you don't have any idea or fix on thy brand new router (paid for nothing)
By now router is configured back to factory default with :
- AP mode
- unset "enable AX"
- unset 20/40 coexistence
- unset AIRTIME FAIRNESS
And it's now better for all devices working 2.4 Ghz and all 5Ghz as iPhones.
I only have sometimes some :
[WLAN access rejected: incorrect security] from MAC address... BUT FOR owned devices (camera printer iPhone)
To be continued if any news
Best regards
Ronald
