ronald_fr
Mar 27, 2020Luminary
RAX40 and iPhone 11
Hello, I encountered some issues with 5G WiFi with various devices, hangs, reset to factory default. No issue since a couple of days and : Yesterday my iPhone 11 (IOS 13.1) had troubles with...
Jasond776
Apr 08, 2020Tutor
I'm having this same problem with RAX40 and iPhone 11 Pro Max. Any updates on this? Does 802.11ax just not work? Thanks
- ronald_frApr 09, 2020Luminary
By now I have not tried to go back to 'enable AX' as I want to have a stable config (too many other issues). iPhone 11 connects fine since AX removed.
I wonder if the RAX40 is not too sensitive to disturbances??? And last night I saw a DFS effect : 5Ghz chan changed 2 times from 56 to 36 !
So I'll not use anymore 56 and I'll try other channels...
Once channel config will be OK, I'll try AX again; I don't want to change more than 1 param at time.
Best regards
Ron
- ronald_frApr 13, 2020Luminary
Hello,
Here are my very last tests:
I used config : AX disabled ; CHAN2.4 = 1 ; CHAN5 = 48 for 3 days w/o troubles.
This afternoon, I enabled AX and there were no immediate troubles; but after a couple of hours, I got 2 known messages :
[WLAN access rejected: incorrect security] from MAC address .....iPhone 11 mac....., Mon,Apr 13,2020 17:15:34
[WLAN access rejected: incorrect security] from MAC address .....iPhone 11 mac....., Mon,Apr 13,2020 17:12:58I opened the iPhone11
- WiFi 5GHz was unreachable (trying to connect to WiFi 5GHz and no internet access)
- WiFi 2.4GHz was running
- and all other devices (not WiFi6 ) were able to connect to WiFi 5GHz !!
All I did was "STOP - START" WiFi 5GHz on the router (Advanced Setup) and the iPhone was enable to connect to WiFi 5GHz again! (not any reboot).
WE NEED a fixed Netgear's Firmware for RAX40!
Best regards
Ronald
- Christian_RApr 15, 2020NETGEAR Employee Retired
Hi Ronald,
I'd like for support to follow up on your issue. May you send me a private message with your case number(s) and email address.
Thanks,
Christian
