UpsidedownWorld
Apr 16, 2019Aspirant
RAX40 and Smart Connect
Just bought the RAX 40 to replace my dying Airport Extreme. One of my main reasons for buying this router was to utilize the smart connect feature so I only have one SSID. I guess this router doesn't...
schumaku
Apr 16, 2019Guru - Experienced User
If it's not available yet in the current firmware [you have checked the Netgear support download pages for the WAX40, right? 1.0.1.46 released 09 April 2019], I'm convinced it will show up later. Technially, there is a little bit more going on behind the UI and over the air than just the same SSID.
As per the Netgear KB What is Smart Connect and how do I enable or disable it on my NETGEAR router? the RAX40 is included, too.
schumaku
Christian_R this might be one more chapter for the currenlty ongoing meeting.
