UpsidedownWorld
Apr 16, 2019Aspirant
RAX40 and Smart Connect
Just bought the RAX 40 to replace my dying Airport Extreme. One of my main reasons for buying this router was to utilize the smart connect feature so I only have one SSID. I guess this router doesn't...
UpsidedownWorld
Hi schumaku ,
Thanks for your response. I do have the latest firmware (1.0.1.41) loaded which is weird because the one listed on the Netgear website is 1.0.1.36.
Good call on the supported routers for the Smart Connect. Looks like it might be on its way in a future release.
The other router I was considering was the RP7000p. Does the RAX40, aside from having support for wi-fi 6, also have superior performance to the R7000p (similar price point)?
schumaku
Apr 16, 2019Guru - Experienced User
Expect similar performance for wired and 802.11ac (5 GHz)/.11n (2.4 GHz) clients - the allowed power is the same, the standards are the same.
