UpsidedownWorld
Apr 16, 2019Aspirant
RAX40 and Smart Connect
Just bought the RAX 40 to replace my dying Airport Extreme. One of my main reasons for buying this router was to utilize the smart connect feature so I only have one SSID. I guess this router doesn't...
michaelkenward
Apr 17, 2019Guru - Experienced User
Both the slightly older RAX80 and RAX120 support smart connect.
- dock8486Apr 17, 2019AspirantAc2600(R7800) or ax3000 (Rax40) which on should I get?
- michaelkenwardApr 17, 2019Guru - Experienced User
Re: Want to Buy a Neatgear router - NETGEAR Communities
I don't think the subject is intended to be ironic.
- jjw001May 02, 2019Tutor
I am really disappointed. I spent a few sessions last week with the support folks looking at various routers that supported smart connect. They assured me that the AX4 did. Now I install one and there is no smart connect option.
- UpsidedownWorldMay 02, 2019AspirantIn addition to the lack of smart connect, I wasn’t happy with the speeds. Didn’t think it was any better than my AirPort Extreme. I took it back, and bought the rax80. Should have done it from the start. So happy with it. This thing screams! Close to 1gig over WiFi!
- michaelkenwardMay 03, 2019Guru - Experienced User
The RAX40 is a new product. In effect you are paying Netgear to be a beta tester.
That is what you get when trying to live on the bleeding edge.
- schumakuMay 03, 2019Guru - Experienced User
Support does work - among internal information - also on the public available resources like data sheet, user manual, and KB. As all these proofed to be wrong or pre-mature, blame has to go to a different channel. Time-to-market pressure has again won over quality, correct information, and more.
Disappointment understood.
