UpsidedownWorld
Apr 16, 2019Aspirant
RAX40 and Smart Connect
Just bought the RAX 40 to replace my dying Airport Extreme. One of my main reasons for buying this router was to utilize the smart connect feature so I only have one SSID. I guess this router doesn't...
michaelkenward
Apr 17, 2019Guru - Experienced User
Both the slightly older RAX80 and RAX120 support smart connect.
dock8486
Apr 17, 2019Aspirant
Ac2600(R7800) or ax3000 (Rax40) which on should I get?
- michaelkenwardApr 17, 2019Guru - Experienced User
Re: Want to Buy a Neatgear router - NETGEAR Communities
I don't think the subject is intended to be ironic.
