UpsidedownWorld
Apr 16, 2019Aspirant
RAX40 and Smart Connect
Just bought the RAX 40 to replace my dying Airport Extreme. One of my main reasons for buying this router was to utilize the smart connect feature so I only have one SSID. I guess this router doesn't...
Amilcoppens
Jul 10, 2019Aspirant
I’m disappointed this doesn’t have smart connect yet. I bought a rax80 and a rax40 expecting the rax40 to have smart connect. I’m going to take them both back and get a different brand that has this feature. I want the same brand and management interface, so I’ll go with another brand that has a lower cost router that has smart connect analog to Netgear. How disappointing. So much on the web says it has these features. I will also file a complaint with the bbb. I HATE when manufactures waste my time, misrepresent their products, and then don’t come through with anything other than empty promises.
schumaku
Jul 12, 2019Guru - Experienced User
Initially around product launch, there had ben some traces of Smart Connect on the RAX40.
So where is this "so much on the Web" please? Neither the RAX40 marketing blush nor the documentation nor e.g. the KB entry indicate that Smart Connect is available.
Netgear was transparent with this - some posts above here Christian_R (as a Netgear rep) stated (around 26 April 2019):
Christian_R wrote:Hello (xxxx) Smart Connect will be supported in the near future but we do not have an ETA of when.
Not convinced there are many other vendors with such a competitive line-up of Wi-Fi 6 routers as Netgear has, and including a basic Wi-Fi 6 AX3000 (four streams) offering.
- michaelkenwardJul 12, 2019Guru - Experienced User
None of the documentation for the RAX40 mentions "smart connect".
>>>RAX40 | Product | Support | NETGEAR<<<
While that may not be a reliable source of the latest information, it is a good place to check for details of key features you want before you part with money.
If the documentation does not mention smart connect, don't expect to see it. Buy something that does. The RAX80, for example.
