0spacetime0
Aug 20, 2023Follower
rax40 ax3000 firmware update
I am using rax40 ax3000 from a while now, there are little issues that need to fixed, its firmware that is available for now like 1.0.5.1.0.4 is 14 months old, other devices are updated regularly as I...
Kitsap
Aug 20, 2023Master
0spacetime0 wrote:
I am using rax40 ax3000 from a while now, there are little issues that need to fixed, its firmware that is available for now like 1.0.5.1.0.4 is 14 months old, other devices are updated regularly as I see. can anyone guide me about the new firmware or Should i assume that rax40 is reached end of support. Thank you
The firmware version 1.0.5.1.0.4 is the current version. You should not put too much focus on how long ago it was updated.
Bad assumption on your part to conclude it has reached end of support. Below is the link to the official Netgear End of Service hardware list. You will note in the router section there is not one RA series.device listed!
https://www.netgear.com/about/eos/
If you are having issues with your RAX40, most likely it is due to configuration issues with respect to the router or the upstream modem/ONT. If you want help with those, describe the details and ask.
