network_noob
Dec 10, 2020Aspirant
rax40 bridged slow wifi
I have been noticing my wifi slow down recently and I can't seem to figure out why. I have my centrylinkC1100T set up bridged with an Ax4 RAX40 ax3000 router. I am getting only half of the speed that...
network_noob
Dec 11, 2020Aspirant
I reset my modem/router and connected my nighawk router to it. Then I put the nighthawk router in AP mode but now it just tells me that there's no internet connection. What steps am I missing?
Dec 11, 2020Guru - Experienced User
If you log intot the isp supplied device, is it in router mode?
Is it broadcasting wifi and can you connect to it and browe?
- network_noobDec 11, 2020AspirantYes
- plemansDec 11, 2020Guru - Experienced User
how do you have the rax connected to it?
lan port from isp router to wan port on RAX?
And the rax is in access point mode?
- network_noobDec 11, 2020AspirantYes exaclty like that
If you log into the ISP supplied router, it should be giving the RAX an IP address since its controlling dhcp. Is it assigning an IP address?
- network_noobDec 12, 2020AspirantYes it is I think but the WiFi very slow and unstable
- plemansDec 13, 2020Guru - Experienced User
network_noob wrote:
Yes it is I think but the WiFi very slow and unstableWhat speeds as follows:
Centuryilnk device:
Wired:
wireless 2.4ghz:
Wireless 5ghz:
RAX200-
wired:
wireless 2.4gh:
wireless 5ghz 1:
wireless 5ghz 2:
What device are you testing on?
What speeds do you pay for from centurylink?
