network_noob
Dec 10, 2020Aspirant
rax40 bridged slow wifi
I have been noticing my wifi slow down recently and I can't seem to figure out why. I have my centrylinkC1100T set up bridged with an Ax4 RAX40 ax3000 router. I am getting only half of the speed that...
Dec 11, 2020Guru - Experienced User
how do you have the rax connected to it?
lan port from isp router to wan port on RAX?
And the rax is in access point mode?
network_noob
Dec 11, 2020Aspirant
Yes exaclty like that
- plemansDec 11, 2020Guru - Experienced User
If you log into the ISP supplied router, it should be giving the RAX an IP address since its controlling dhcp. Is it assigning an IP address?
- network_noobDec 12, 2020AspirantYes it is I think but the WiFi very slow and unstable
- plemansDec 13, 2020Guru - Experienced User
network_noob wrote:
Yes it is I think but the WiFi very slow and unstableWhat speeds as follows:
Centuryilnk device:
Wired:
wireless 2.4ghz:
Wireless 5ghz:
RAX200-
wired:
wireless 2.4gh:
wireless 5ghz 1:
wireless 5ghz 2:
What device are you testing on?
What speeds do you pay for from centurylink?
