Chick832
Apr 16, 2020Tutor
Rax40 can’t connect to internet
Received the router today and spent 2 hours to setup but in vain. From app it often says can’t connect to internet. No matter how many times to power off and on, still can not detect internet, even...
- Apr 17, 2020
Hello Chick82,
Please factory reset the router by holding down on the reset button for 15+ seconds. After doing so please use the Nighthawk app to setup the router. Furthermore, you may also contact our support team for setup assistance: https://www.netgear.com/support/default.aspx
Christian
Christian_R
Apr 17, 2020NETGEAR Employee Retired
Hello Chick82,
Christian
Chick832
Apr 17, 2020Tutor
After resetting 3 times it suddenly works
Thanks god!
However once connected to internet successfully ,
I can’t send photo via WhatsApp but sending text is ok. Any clue on router setup ?
Thanks god!
