Fjalar82
Jan 11, 2022Follower
RAX40 Can't surf the web via OpenVPN
I recently configured my RAX40 (latest firmware) with VPN service and got me a ddns.net.
I marked "all sites on the Internet & Home Network" in the VPN Service configuration because I want to surf the web, via for example google chorme, with it.
This is not working!
From www.showmyip.com Im still getting my "old" IP.
I can, however though, access my local computers and can ping my router. All this from a laptop with windows 11.
I've copied the configfile from my router. A pretty basic one. Pasting it below:
client
dev tap
proto udp
dev-node NETGEAR-VPN
remote xxxxxxxx.ddns.net 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
I can see a few errors in the log. But since I've just copied the config file created by netgear it should be any problems?
But I past them below anyway
2022-01-11 13:06:02 us=937000 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Jan 11 13:06:07 2022 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Tue Jan 11 13:06:07 2022 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.1.0
Tue Jan 11 13:06:12 2022 NOTE: unable to redirect IPv4 default gateway -- VPN gateway parameter (--route-gateway or --ifconfig) is missing
Tue Jan 11 13:06:12 2022 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Tue Jan 11 13:06:12 2022 AEAD Decrypt error: bad packet ID (may be a replay): [ #4 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
Tue Jan 11 13:10:36 2022 write UDP: Unknown error (code=10051)
Any ideas anyone?
No RepliesBe the first to reply
