SLO-Life
Dec 04, 2020Follower
RAX40 crashes when netgear range extender is connected
I replaced my R6300 WiFi router with a new RAX40 WiFi Router (and new NetGear cable modem too) . With my old WiFi router my WN3500RP extender work almost flawlessly in both 2.5 and 5G range extending,...
Ch4rlus
Apr 21, 2021Aspirant
I'm having a similar issue, I've created this thread to get some help: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX40-Wifi-SSID-disapear-when-connecting-extender/m-p/2086671/highlight/true#M18546
So far no luck.
Have you found a solution or do you recommend buying another router ?
