McDime
Apr 17, 2020Tutor
RAX40 does not save "Disable Port Scan and DoS Protection"
While debugging an issue with my RAX40 dropping regularly a connection to the Internet, I found out that the setting "Disable Port Scan and DoS Protection" can be set, but it will be cleared again after some time. Like next day it is unchecked again.
And so far all logging entries with regards to DoS are defentily false-possitive, so I suspect this psuedo-protection could be a possible issue in my case.
Is it a bug or a feature that this settings is unchecked/reset back after some time?
No RepliesBe the first to reply
