rvbqsdf
Aug 31, 2019Follower
RAX40 dropping internet connection
It seems the router drops internet connection quite randomly. Modem.router does have internet access, so problem is due to the RAX40. 2nd item. It seems that multicast UDP is not supported how can i...
MGorgol
Dec 15, 2019Star
Hello mine also drops randomly and does so with the most recent firmware.
snowcoyote
Feb 02, 2020Guide
Current firmware V1.0.3.64_1.0.1.
Still see occasional connection lags on wifi, usually brief. This morning I had to reset the router completely. The logs showed a DOS attack on port 443, when I looked up the IP it was from my wifes work email server. I will start taking screenshots with Wifi Speed Test. After reboot I'm seeing 126MBit upload with 4ms latency. Before reboot it wasn't working at all. Clearly the router and not the modem.
