rvbqsdf
Aug 31, 2019Follower
RAX40 dropping internet connection
It seems the router drops internet connection quite randomly. Modem.router does have internet access, so problem is due to the RAX40. 2nd item. It seems that multicast UDP is not supported how can i...
WilsonNWT
May 11, 2020Aspirant
Same here. My RAX40's WIFI is no longer connecting to internet since 9 May 2020. But my app in mobile remote access to the router and stated that the network is fne, with speed test. So i believe there is error in RAX40's WIFI purely. I didn't try factory reset as I want to make sure this is the last resort. Is it about the fireware v1.0.3.64_1.0.1?
ronald_fr
May 12, 2020Luminary
Hi,
I purchased RAX40 last October. Since february this is a nightmare :
- iPhone 11 is unable to connect
- admin web hangs
- random resets to factory default
- full system hangs >>> power off-on with some resets to factory default
open SR @ Netgear's support about iPhone11 .... waiting for news soooooo long!
(F/W 1.0.3.64_1.0.1 AX enabled)
BR
Ron
