rvbqsdf
Aug 31, 2019Follower
RAX40 dropping internet connection
It seems the router drops internet connection quite randomly. Modem.router does have internet access, so problem is due to the RAX40. 2nd item. It seems that multicast UDP is not supported how can i...
pbulteel
Jun 23, 2020Star
To anyone reading this looking for a solution. If you can return your RAX40, do so. RUN! DO NOT LOOK BACK!
This router is **bleep** and the firmware that are being released are the worse thing I have ever seen.
Imagine having to reset you Android device after every update? Imagine having to downgrade because it stops working.
Just do yourself a favor, go return it!
