rvbqsdf
Aug 31, 2019Follower
RAX40 dropping internet connection
It seems the router drops internet connection quite randomly. Modem.router does have internet access, so problem is due to the RAX40. 2nd item. It seems that multicast UDP is not supported how can i...
joshy194
Sep 02, 2020Initiate
Having the same issue. Once to twice every day, all devices loose wifi connection. I guess none of you tried to use to enable the access control? Whenever the router is re-starting, randomly devices are getting blocked and you have to somehow get to the router and disable the access control. The support was not of help either. The person hardly understood was i was talking about. At least he tried.
Don't know if I'm going for a Netgear device again.
