rvbqsdf
Aug 31, 2019Follower
RAX40 dropping internet connection
It seems the router drops internet connection quite randomly. Modem.router does have internet access, so problem is due to the RAX40. 2nd item. It seems that multicast UDP is not supported how can i...
Angef
Oct 22, 2020Aspirant
I was having the same issue. Ensure that the Modem is set up in Bridge mode (not as a Modem / Router).
Seems to have fixed the problem.
rvbqsdf wrote:It seems the router drops internet connection quite randomly. Modem.router does have internet access, so problem is due to the RAX40.
2nd item. It seems that multicast UDP is not supported how can i be sure the router does not transmit multicast UDP over wifi?
