rvbqsdf
Aug 31, 2019Follower
RAX40 dropping internet connection
It seems the router drops internet connection quite randomly. Modem.router does have internet access, so problem is due to the RAX40. 2nd item. It seems that multicast UDP is not supported how can i...
Chana88
Oct 29, 2020Apprentice
Hi I went back to .64 firmware as everyone was suggesting this cures the WiFi dropouts
but in my case this made it worse nothing connecting WiFi and lan dropouts
so I went back to .80 firmware so far all good
no reboot for a week and no dropouts
no idea what going on there
Chana88
Any one got the beta firmware we can try out
- snowcoyoteOct 29, 2020Guide
I haven't had issues in months. Latest firmware (V1.0.3.80_1.0.1) seems fine to me. Turned of Qos Disable AX and smart connect. Not saying this is an option for everyone, but work for me.
May also help to make sure you are only on one wifi network and Android isn't toggling between 2.4 and 5G. I found my phone was getting stuck on 2.4 and running slow.
- itsmehueyOct 29, 2020LuminaryBeta cannot be shared. You just obtain from support.
- Chana88Oct 30, 2020Apprentice
No worries old pal I won't share my knowledge with you you obtain it from support
don't need it any way working a treat with .80 software
with AX on
no drop out or reboots
- itsmehueyOct 30, 2020LuminaryOk then good for you. I was simply saying that it must be obtained through Netgear support and cannot be shared. That’s all part of the user agreement of the beta testing that it cannot be freely shared. So no need to be passive aggressive about it.
