ngrover
Jul 13, 2020Guide
RAX40 dropping signal
Anyone else experiencing signal loss randomly with latest firmware? ISP is good, router works fine after reboot, but it's almost daily and sometimes twice a day. Running Firmware V1.0.3.80_1....
- Jul 14, 2020I ended up swapping for an ASUS AX3000. This being the final straw, I have had multiple issues over the last year and change from SmartConnect not working at all to spontaneous reboots. I couldn’t go much more than a week without some sort of issue.
Filipus
Aug 06, 2020Tutor
How don't we have answers to this??
I've been having this problem since I got the router a few months ago. I thought it was my internet at first but it didn't make any sense.... And I can't really return the router now. Finally found this today, feel like an idiot for trusting netgear.
Will warranty give us a different router? Are there plans for a fix for this?
Dustin_V we need some answers.
xpm
Aug 06, 2020Star
I believe the warranty is a year but support or premium support that comes with the purchase is only 90 days. After which they SELL or want you to buy premium support. All I can say is if they replace the router and I still have the issue, Netgear is out and I will be looking for an ASUS or TP Link etc. I frankly think their support sucks and their firmware updates suck also. They don't seem to be in an hurry to fix the firmware. By the way, their support is in India and it is sometimes difficult to understand them. The support tech that I talked to told me that they would send a replacement if the adjustments I made to the settings at their direction did not work. Now I'm wating to see if they are true to their word and send a replacement that will work. I'm not getting my hopes up on anything.
- itsmehueyAug 06, 2020Luminary
I've just opened up a support request, but not counting my lucky stars that I'm going to get any actual useful support on this at all..
- whyfyAug 08, 2020TutorNETGEAR support asked me to downgrade to v1.0.3.64 and reset router. Surprisingly it fixed the WiFi dropped signal. NETGEAR told me not to upgrade back to v1.0.3.80. My 90 day free support ended couple days after I reached out. Really weird downgrade is the best solution so far
- itsmehueyAug 08, 2020Luminary
What's even more pathetic is that they included this in the v1.0.3.80 firmware release notes:
Bug Fixes:
Fixes the WiFi driver crash issuePffttt... WIFI driver crash issue fixed? They forgot to include "Introduces even more WIFI dropout issues." in the release notes.
