ngrover
Jul 13, 2020Guide
RAX40 dropping signal
Anyone else experiencing signal loss randomly with latest firmware? ISP is good, router works fine after reboot, but it's almost daily and sometimes twice a day. Running Firmware V1.0.3.80_1....
- Jul 14, 2020I ended up swapping for an ASUS AX3000. This being the final straw, I have had multiple issues over the last year and change from SmartConnect not working at all to spontaneous reboots. I couldn’t go much more than a week without some sort of issue.
xpm
Aug 09, 2020Star
I spent about 45 minutes on the phone with tech support yesterday. This is in addtion to the hour I spent on the phone with them a few days ago. Three times during the call yesterday I was placed on hold while I assume the tech discussed it with her supervisor or manager etc. In my first phone call with tech support, I made changes to the settings at there direction and it did not solve the problem. I was told last week that I would be sent a replacement router if those changes did not fix the problem. Yesterday they told me that I needed to reflash the firmware manually before they would sent a replacement. So, it seems they are doing all they could NOT to send a replacement. If the firmware is problematic, then what good is a reflash of the firmware. I seriously think buying Netgear in the first place was my biggest mistake. Someone on this forum said the only thing that solved the problem was to buy a ASUS router. They said they never had a problem since they got the new ASUS router. I firmly believe that If you want a reliable product with good tech support, DO NOT buy NETGEAR. You will regret it if you have problems with their product like I am right NOW.
Bentl78
Aug 09, 2020Guide
I won’t be buying another one.. obviously they don’t even know that it is a wide spread problem.. it’s all over the forum.. but they still don’t acknowledge it... and need to spend so much time figuring it out with u
