ngrover
Jul 13, 2020Guide
RAX40 dropping signal
Anyone else experiencing signal loss randomly with latest firmware? ISP is good, router works fine after reboot, but it's almost daily and sometimes twice a day. Running Firmware V1.0.3.80_1....
- Jul 14, 2020I ended up swapping for an ASUS AX3000. This being the final straw, I have had multiple issues over the last year and change from SmartConnect not working at all to spontaneous reboots. I couldn’t go much more than a week without some sort of issue.
owenico
Sep 07, 2020Guide
In my guess, you didn't completely revert back to the older version firmware/
My layman suggestion:
1) Disconnect all the devices from router
2) Do the factoy reset, be patience in order to let this machine do it completetly & auomatically
3) Refresh the V64 firmware, be very very patience again.
Hope this can work!.
If problem insisted, do the same thing of me, buy a new Asus AX3000!
Anand_2684
Sep 07, 2020Aspirant
I tried all of that again, and it didn't work unfortunately. I guess I'm gonna have to go for the ASUS now. No issues with the Asus till now
owenico wrote:In my guess, you didn't completely revert back to the older version firmware/
