ngrover
Jul 13, 2020Guide
RAX40 dropping signal
Anyone else experiencing signal loss randomly with latest firmware? ISP is good, router works fine after reboot, but it's almost daily and sometimes twice a day. Running Firmware V1.0.3.80_1....
- Jul 14, 2020I ended up swapping for an ASUS AX3000. This being the final straw, I have had multiple issues over the last year and change from SmartConnect not working at all to spontaneous reboots. I couldn’t go much more than a week without some sort of issue.
Chana88
Oct 27, 2020Apprentice
I went back to software 1.0.3.64 as others suggested it sovles wifi drop outs
Mine was even worse wifi dropping out lan ports dropping out
So only solution was to upgrade back to 1.0.3.80
Since putting this back on had no wifi drop outs or lan port drop outs so fingers crossed this has worked
- itsmehueyNov 04, 2020Luminary
OK after weeks and numerous follow ups to my L2 support representative, they finally have another beta for me to test.. RAX40-V1.0.3.83_1.0.10 dated 4th November 2020
I'll be testing and monitoring over the course of the week and will report back my findings and experience with the update.- Chana88Nov 05, 2020Apprentice
Thanks pal keep us updated with your findings
- CTrainNov 08, 2020Aspirant
I have nothing substantial to add but I just want to add my voice to the list of people experiencing problems.
I have also past the return period for this and so have swapped it 3 times through an RMA for defective merchandise. I complained to the vendor about how I'm stuck with this - instead of immediately returning it I spent hours and days with tech support, therefore going past the return period.
I am looking forward to a firmware update which I hope makes this thing usable. But after this experience I won't be buying a Netgear product again.
