ngrover
Jul 13, 2020Guide
RAX40 dropping signal
Anyone else experiencing signal loss randomly with latest firmware? ISP is good, router works fine after reboot, but it's almost daily and sometimes twice a day. Running Firmware V1.0.3.80_1....
- Jul 14, 2020I ended up swapping for an ASUS AX3000. This being the final straw, I have had multiple issues over the last year and change from SmartConnect not working at all to spontaneous reboots. I couldn’t go much more than a week without some sort of issue.
z3n
Dec 05, 2020Guide
Just flashed the 1.03.88 firmware. Still seeing drops on 5ghz wifi network, at least twice in the last 30mins.
Haven't factory reset yet, might try that.
- itsmehueyDec 05, 2020Luminary
Haven't factory reset yet, might try that.wow, seriously?? looks like i'll be sticking to my beta then.. haven't had a single drop for 5 weeks with wifi6/AX enabled, and more than half of my devices on the 5ghz band
