ngrover
Jul 13, 2020Guide
RAX40 dropping signal
Anyone else experiencing signal loss randomly with latest firmware? ISP is good, router works fine after reboot, but it's almost daily and sometimes twice a day. Running Firmware V1.0.3.80_1....
- Jul 14, 2020I ended up swapping for an ASUS AX3000. This being the final straw, I have had multiple issues over the last year and change from SmartConnect not working at all to spontaneous reboots. I couldn’t go much more than a week without some sort of issue.
Ghostdragon87
Dec 05, 2020Tutor
I'm still on version .80 and it's been good for me although I had to disable a chunk of features just to make it stable. I'm not sure about trusting .88 just yet as it might make things worse. They did just release a v2 of the Rax40 so .88 might be to finish bricking the v1 rax40 to convince people to upgrade.
CTrain
Dec 31, 2020Aspirant
I've been using .88 for a week now and the signal doesn't outright drop as much but it's significantly weaker and I reboot it once or twice daily. Tonight is the first time it's dropped completely. I've rebooted a few times and the signal is weaker than usual - I can't even connect from where I usually use it from.
