ngrover
Jul 13, 2020Guide
RAX40 dropping signal
Anyone else experiencing signal loss randomly with latest firmware? ISP is good, router works fine after reboot, but it's almost daily and sometimes twice a day. Running Firmware V1.0.3.80_1....
- Jul 14, 2020I ended up swapping for an ASUS AX3000. This being the final straw, I have had multiple issues over the last year and change from SmartConnect not working at all to spontaneous reboots. I couldnât go much more than a week without some sort of issue.
Sfpalle
Jan 03, 2021Aspirant
Hi everyone. If you want your RAX 40 50 80 to work degrade your FW to 1.0.3. 64_1.0.1
This will fix the wifi signal dropp. For me it did đ
- itsmehueyJan 03, 2021LuminaryEveryone already knows that... but everyone also knows that it is not a fix. Only a workaround.
- CTrainJan 09, 2021Aspirant
For me firmware 1.0.3. 64_1.0.1 was about the same. I lose Internet with it still. It's just now my computer tells me there's no Internet, rather than showing the "Connected" symbol (Windows 10 version 2004).
