Minh10n
Dec 21, 2020Follower
RAX40 Dropping wifi signal
I am running the latest firmware V1.0.3.88_1.0.1...and wifi keeps dropping. i followed netgear support by phone and its still doing this here and there. i called my internet provider and we tried bridge connection and unbridged, also company even resetted the connection and works fine. the router keeps dropping signal and im getting furious with it. any solutions?
My drivers are up to date and i did factory reset it like 3 times and downloaded the file and reinstalled the update manually while cable connected from the router.
1 Reply
- z3nGuideThis is a known issue with RAX40. You can try rolling back the firmware as per other posts, however my recommendation is to try and get Netgear to replace your device with a newer model, or return it to the retailer and get a refund. There is some critical flaws with this router and honestly not worth the time it takes to troubleshoot it.
