Crkoshay
Nov 04, 2020Aspirant
RAX40 fals DoS
My router just randomly drops my internet for about a minute every 30 minutes or so. I think it has to do with DHCP lease.I have it set to 24 hours. I am using the ATT gateway on IP passthrough mode....
microchip8
Nov 04, 2020Master
Most of these are false positives, local addresses. I suggest turning off logging of DoS attacks and if you're brave enough, completely turning off DoS protection. I run with DoS protection off for years now without a single issue
Crkoshay
Nov 05, 2020Aspirant
I am pretty sure the issue is that my DHCP is not auto renewing. My connection keeps dropping 5 minuts before my 24 hour lease is set to expire.
