Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
pbulteel
Jun 19, 2020Star
I also wanted to add that there's still an issue with devices on 5G getting rejected even though the PSK is correct. They can connect to 2.4G with the same PSK. This issue was happening before this version, but it hasn't been fixed.
Minor thing: They misspelled "unknown" - says "unknow" for detected devices.
I mentioned that sometimes the router is unreachable but the internet is. That's not proven to be the case all the time this happens. There are times when it does drop the internet connection and in fact, if on wifi, non of the other devices are reachable. If I'm on the LAN, I am not connected to the router asI have a switch, and all devices that are NOT on the router are reachable. Those that are on LAN on the router, are not reachable.
I have also noticed that although log is suppose to show everything (all checkboxes are ticked) - there's a lot of things that do not show up. I don't see wifi devices connecting, etc. I only get DOS notifications and access to LAN from internet (port forwarded). And disconnect/connect to internet. Other than that, I don't see anything else.
