Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Christian_R
Jun 22, 2020NETGEAR Employee Retired
Hello Nighthawk AX Community,
Thanks for sharing your feedback. I'll have the information forwarded to our product teams. In the meantime, may you confirm and let me know if reverting to the previous firmware version helps.
Thanks,
Christian
pbulteel
Jun 23, 2020Star
- Christian_RJun 23, 2020NETGEAR Employee Retired
Hello Community,
Thanks for confirming that reverting back to the previous FW helps with the issues. I've forwarded the feedback to our product teams and I'll update the thread as soon as I can.
Shout out to Retired_Member for starting a bug thread as this process helps us and our product teams consolidate the feedback.
Best regards,
Christian
- A_OchoaJun 24, 2020Tutor
Same issue with my RAX35, how do I downgrade the Firmware?
- ronald_frJun 24, 2020Luminary
Hi
goto https://www.netgear.com/support/product/rax35.aspx#download
download 1.0.3.62 zip file
unzip it
open router's webinterface >>> Advanced >Administration -> Router Update
browse to location of unzip files and select the binary image and Upload it
Cross Fingers
BR
Ron
- ncdancerJun 30, 2020Guide
Christian_R wrote:Hello Community,
Best regards,
Christian
Hi Christian_R,
I have been having similar issues; not sure when the router drops started but it seems like a couple of weeks. I was restarting sometimes once a day at first then it increased to every day and yesterday had to restart three times. I have now reset the router back to factory setting and accepted the firmware Version V1.0.3.80_1.0.1 update during the install.
I have not changed any default settings except for naming the devices and attaching icons, I have done this on the web and on the app; however I see that the smart lock icon is showing up generic in the app and when I try to change it on the app, it doesn't stick.
I'm on the latest os's on a mac and ios. I have 4 wired devices and eight wireless devices.
Thank you for looking into this.
- TOKEN_Aug 27, 2020TutorChristian_R how are you going with the net gear teams you where in contact with. You have been very quiet on the topic considering you where asking for more information so you could pass to the support teams.
- Eagle-TwoAug 27, 2020Apprentice
Yesterday all of my devices on the 5Ghz band wouldn't connect to the router. They would connect and immediately disconnect. The 2.4Ghz band continued to work fine. After rebooting the router, everything worked properly again. Is there a way to reboot the router on a schedule? Is there a way to submit a bug report to Netgear after the technical support period ends? This weekend I might try downgrading the firmware.
