Retired_Member
Jun 17, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
Christian_R
Jun 23, 2020NETGEAR Employee Retired
Hello Community,
Thanks for confirming that reverting back to the previous FW helps with the issues. I've forwarded the feedback to our product teams and I'll update the thread as soon as I can.
Shout out to Retired_Member for starting a bug thread as this process helps us and our product teams consolidate the feedback.
Best regards,
Christian
A_Ochoa
Jun 24, 2020Tutor
Same issue with my RAX35, how do I downgrade the Firmware?
- ronald_frJun 24, 2020Luminary
Hi
goto https://www.netgear.com/support/product/rax35.aspx#download
download 1.0.3.62 zip file
unzip it
open router's webinterface >>> Advanced >Administration -> Router Update
browse to location of unzip files and select the binary image and Upload it
Cross Fingers
BR
Ron
- Rkohl1956Jun 24, 2020GuideHey thanks Ron. I actually did that back when I had the issue - problem solved. I put the post in here to comply with Bushmaster request to consolidate all posts regarding this issue in this thread. But I do appreciate your offer of help, as it is the correct solution. Stay healthy!
- IndrajitJun 28, 2020Guide
Hi Ron,
I would like to get help, please break down the steps how to do:
I don't know exactly how to do it, because I am not so knowledgeable. Appreciate.
IS
