Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
rplc
Jun 26, 2020Tutor
Two major issues after 1.0.3.80 upgrade:
A. Every time after reboot, the saved access control MAC addresses and access rights are completely and randomly corrupted. The only solution so far is to factory reset the router, which is very frustrating.
B. I tried to back up the settings to save some work after factory reset. But the backup file does not contain the saved MAC addresses and access rights at all! That means I have to re-enter a whole list of MAC addresses and names every time after a reboot. Can the support team include access control data into the backup file / restore process please?
A relatively less critical issue is the wrong password problem after switching to WPA3 (Personal). The router fails to recognize saved WIFI password. A fallback workaround is to use the WPA2+WPA3 option instead of WPA3 (Personal). Obviously it is a bug, however.
