Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
scott2003lhs
Jun 30, 2020Star
Still same issues with a rollback. I really can’t believe how awful this is. Went through level 2 tech support. Company stands behind their products a whole ninety days! Lol. The software for this RAX 40/35 is a mess. I wish we could get refunds. This is a joke. Lost a customer for life.
A_Ochoa
Jun 30, 2020Tutor
Reveted to 62 no luck.
Reset to Factory settings, no luck.
Went back to my little old Trendnet, no problems now.
Whish I nevee spent so much on this device, at least it was on a Black Friday sale.
Can't disable coexistence because my BluRay uses the 20Mhz network and my other devices use the 40.
- carmineaJul 01, 2020Star
ok, what i learned is to download the older firmware version from Netgear website, look for the older version
V1.03.64_101 and go into the Admin settings of the route and update firmware manually.
After i did that everything works again back to normal. It tooks me a few days of playing with setting and resets, but today i downloaded and tried the older version and it works
give it a try. Also turn off auto updates so it doesnt happen again, and hopefully another update will come out
stay away from 3.80 version
- scott2003lhsJul 02, 2020StarFor myself I had the same drop and disconnects on the older firmware. I suspect DHCP authentication issues when a device tries to reconnect after being off or away. It tries to assign the old IP to it, fails, and gives is a 169.xxx etc address, which means authentication failure. I’m not a network engineer, but DHCP service should be one of the first things you get right. Hope they find fixes... soon
- ronald_frJul 06, 2020Luminary
Hello,
I'd like to know wth is this bad firmware always available (download or upgrade by router) ?
Should be removed !
BR
Ron
