Retired_Member
Jun 16, 2020RAX40 Firmware 1.0.3.80 Crash/Bug Log
Hello folks, can everyone please log all the issues they are experiencing with the RAX40 router on 1.0.3.80 firmware under this thread, I see there are several threads going on about the issue, figur...
benoit_fr
Jul 11, 2020Apprentice
FYI, like a lot of us, I had serious stability problems.
No issues for 2 days and then wifi breaks for all the home devices. Ethernet was stable.
It happened 3 times in the week.
Checked and modified my Wifi settings stable for a couple of weeks :
Disabling Smart Connect and having the same SSID for 2.4 and 5ghz
Disabling Mix mode WPA2/WPA3 and using only WPA2 AES
Just FYI.
Hope we will have soon a good firmware....
kvik369
Jul 15, 2020Guide
So is your router still stable or has the issues resurfaced?
- MaxgurJul 15, 2020Guide
The problems remain. At a frequency of 5 GHz, the channel is reset to 36. Sometimes, communication with devices connected at a frequency of 5 GHz disappears. I can not connect to the hard drive that is connected to the router. I hope that they will fix the problems in the new firmware ...
- IndrajitJul 15, 2020GuideMy router shut down completely and doesn’t communicate with PC or Netgear app at all, no internet connection at all, it’s totally dead. I tried everything possible can, not responding to anything. Disappointed very much. Got this router in December 2019, Netgear will not do anything unless I purchase their service.
- kvik369Jul 15, 2020Guide
Just curious - I actualy have a RAX35 with the same issue I'm powering the router off and on in the AM with a hardware timer. Usually this keeps it fine the whole day but sometimes I still lose internet and have to power cycle the router again Thanks for the update
- benoit_frJul 17, 2020ApprenticeSo far so good. No more reboots / problems.
